Last Active: 8 Years Ago
Visits: 2
Hi
New here, ****o to everyone.
When using the shaper/router table to cut a 6mm deep groove using the Router Bit (HSS) 6,4 mm (654) in plywood, the tool cuts out and is also making the wood burn badly. I have tried to do it in 2 passes 3mm deep each time, still the same.
Any help or is the tool not up to the job?
Visits: 2
why has ****o, turned into ****
