Dremel Message Board
Dremel Brushes Expand / Collapse
Author
Message
Posted 1/18/2011 7:46:58 PM
Junior Member
Junior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior Member
Last Login: 1/18/2011 7:41:12 PM
Posts: 11, Visits: 26
I have Rotary Tools  models 200 & 300 series .What brushes amodel numbers replasements for tools.
Sincerly Gary
Post #7548
Posted 1/19/2011 1:30:56 PM
Forum Guru
Forum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum Guru
Last Login: 11/13/2011 4:00:41 PM
Posts: 64, Visits: 698
I checked the catalog and you want for either one 90930-04 you should be able to get them at any store that sells Dremel and if not call Customer Service at 1-800-437-3637 (or whatever 4Dremel translates to.
Post #7549
Posted 6/6/2011 12:15:48 AM
Forum Newbie
Last Login: 6/18/2011 11:10:26 PM
Posts: 8, Visits: 12
If you can't get the proper motor brushes at your local store, you might try what I did the other day on one of my Dremel tools.
I bought a set that should have worked, but was a little to large for the opening in the motor housing, the package said for all Dremel tools
but was a misprint. I took one of the new brushes and a piece of fine sandpaper, and gently sanded two opposite sides of the new brush
until it slid into the housing like it was made for it...only took a few minutes, but save another trip to he hardware store. Make sure you orientate the brushes properly before installing them into the tool.
These little brushes are just pieces of carbon with a spring attached
to keep them under pressure to the armature shaft, so they are easy to modify if needed. eezlock
eezlock
Post #7906
« Prev Topic | Next Topic »
Forum Moderators: AlyssaCicero
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 7:42pm
Execution: 0.016. 7 queries. Compression Disabled.
