Dremel Router Bits for Derby Car
Author
Message
HangTenKen
View Quick Profile
Forum Member
Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)
Last Active: 8 Years Ago
Posts: 1, Visits: 2
I want to create a new channel beneath and athwart my derby car in order to receive a 3/8" dowel used as the axle.  I see a routing bit 617 (I think) Core Box bit that would make the chanel for me, but it's the wrong size.  Where can I find a 3/8" Diameter round nose router bit (1/8" shank) that I could use on my Dremel to route the "half-pipe" channel needed for my axle?
wayner
View Quick Profile
Supreme Being
Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)
Last Active: 5 Years Ago
Posts: 82, Visits: 547
To my knowledge you will not find a larger router bit for the dremel.
Unfortunately you will have to enlarge the grove manually, one pass at a time.  The problem with a larger bit is that it would require more torque to run than the tool could supply causing it to burn out prematurely.  Hope this helps.Hehe
Wayner   Wink
Reading This Topic
