dremel 4000 is a wast of time to buy!
Author
Message
handy man
View Quick Profile
Supreme Being
Supreme Being (89 reputation)Supreme Being (89 reputation)Supreme Being (89 reputation)Supreme Being (89 reputation)Supreme Being (89 reputation)Supreme Being (89 reputation)Supreme Being (89 reputation)Supreme Being (89 reputation)Supreme Being (89 reputation)
Last Active: 8 Years Ago
Posts: 5, Visits: 11
PURCHASE A DREMEL 4000. GOT IT OUT OF THE BOX THE FIRST THING THE ROTARY SWITCH WENT AFTER HAVING IT ON WITH NO LOAD FOR 5 MINUNTS. WHEN YOU REV IT UP TO 535000 RPM THEN YOU SLOWLEY BRING IT BACK THE REVS GOES UP OR DOWN NOT A STEADY DOWN SPEED.
THEN IT CAME BACK WORKING WHEN YOU PUT A SANDING DISC IN YOU CANT BALANCE THE WHEEL AND THE MOTER MAKES A CLICKING SOUND. THIS IS BECAUSE THE SHARFT IS NOT MACHINE TRUE. THIS WAS ON 3 UNITS.
ITS HEAVY AND YOU DONT KNOW WERE TO HOLD IT.
AND FOR ANY ONE THAT IS THINKING OF BUYING ONE DONT THIS TOOL IS NOT SAFE YOU CAN EASLY SWITCH THE UNIT ON INSTEAD OF HOLDING THE LOCKING BUTTON DOWN TO TIGHTEN THE BIT AS THE THE COULOUR OF THE SWICH ANDTHE LOCKING BUTTON IS THE SAME COLOUR BLUE.
WHEN YOU SWITCH IT TO 5000RPM IT FEELS LIKE ITS GOING TO DIE IT DOES NOT HOLD ITS REV STEADY DREMEL SAID THIS IS NORMAL I THINK THEY MADE THIS UNIT TO FAST JUST TO GET IT OUT IN THE MARKET. WHEN YOU HOLD THE TOOL ITS UNBALANCE AND THE THE NOISE AND TO MUCH VIBBRATION.
I HAVE TRIED 3 UNITS AND THEY DO THE SAME SO THERE FOR THINK TWICE BEFORE BUYING!
I HAVE READ A LOT ABOUT THIS MODEL ON THE NET AND ALL SAME MUCH THE SAME.
I TOOK A HAMMER TO IT AND DID NOT BOTHER TO SEND IT BACK FOR REPAIR BECAUSE ITS A WAST OF TIME AND ENERGY.
ALSO FORGOT TO MENTION YOU CAN NOT CHANGE THE CARBIN BRUSHES BECAUSE THEY HAVE PUT A BLACK PLUG ON THE TOP AND ON THE BOTTOM THERE IS NO PLASTIC SCREW. THERE FOR YOU HAVE TO OPEN THE HOLE UNIT EVERY SIX MONTHS TO CHECK THE BRUSHES AS THE MANUAL SAYS. WHEN YOU DO THIS IT WILL VOID THE WARRENTY. SO THE NEXT STEP IS TO TAKE TO THE NEARIST DREMEL SERVICE CENTER FOR THEM TO CHECK THE BUSHES EVERY 6 MONTHS THATS TIME AND MONEY FOR THEM TO CHECK IT.
SO AS I SAY AGAIN THINK TWICE!!
goodbye
View Quick Profile
Forum Guru
Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)
Last Active: 7 Years Ago
Posts: 3, Visits: 2
This group movement insanity workout, the back must be close to the ground side up and the hips only slightly raised, insanity can not be too far off the ground, The system provides anti-checkout function key and windows 7 key: to modify the certificate has been closing the accounting period, quickbooks 2012 anti-checkout before. windows 7 download system settings, the certificate lookup feature, my eyes leg with wholesale insanity. Similarly, the hips must be close to the seat by rip 60, even the side of the leg also need to maintain the parallel with bowflex in the seat as possible, do not lift too high. office 2010 key and provides multiple search criteria for users to choose quickbooks download, both for the convenience of users, turbotax download but also improves the search speed. rip 60 electrostatic headphones, ERGO headphones unique shape p90x, the sound is thin and transparent, p90x of but also has a high reputation and insanity dvd. A small company in the United States, beats solo hearing aids and HI-END earplugs product, the ER4 series of earplugs is a classic high-grade earplugs of beats by dre studio, the sound of its products loyal dye ER4 series, ER6, wow gold it is recommended.
aaaaaaaaa
Reading This Topic
