Removing glass scratches
Author
Message
beforejava
View Quick Profile
Junior Member
Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)
Last Active: 8 Years Ago
Posts: 2, Visits: 2
A stone hit my window and caused a deep scratch. Any suggestions on how to remove it using a Dremel?
pipo
View Quick Profile
Junior Member
Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)
Posts: 1, Visits: 3
hey , look there is a rubber head , you might use to remove scratched glass BigGrin , good luck
msprissysmom
View Quick Profile
Forum Guru
Forum Guru (68 reputation)Forum Guru (68 reputation)Forum Guru (68 reputation)Forum Guru (68 reputation)Forum Guru (68 reputation)Forum Guru (68 reputation)Forum Guru (68 reputation)Forum Guru (68 reputation)Forum Guru (68 reputation)
Last Active: 7 Years Ago
Posts: 4, Visits: 4
I used the grinding wire wheel to polish out a mirror that had a lot of Gorilla glue on it and it didn't even scratch it.
Put this cat on
..../\„,„/\ your profile
...( =';'= ) to show
.../*♥♥*\ that you are
.(.|.|..|.|.) against Hartz Products
and Animal Cruelty
Dremel Customer Service
View Quick Profile
Supreme Being
Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)
Last Active: 4 Years Ago
Posts: 109, Visits: 540
****o, this is Beth from Dremel Customer Service.  We don't really have anything that is going to take scratches out of glass.  We do have many accessories in our "Cleaning/Polishing" end, however, again, these are not recommended for removing scratches.  (Some people think they can use the "polishing compound", but that has about a 400 grit in it, which could cause some scratching on it's own).  We offer the "Grinding/Sharpening" stones, but those are really used to "grind" down glass, like the edges... not to remove scratches.  I'm sorry that I wasn't able to provide a better answer in the way of your application, but I certainly don't want you to use one of these things and have a not to pleasant result.  Thanks for your question.  If you have others, you can also feel free to call our Dremel Customer Service Department on the toll free phone number of 1-800-437-3635, Monday - Friday, 7:00 am - 6:00 pm, CST.
-Dremel Customer Service Team
Reading This Topic
