8200 Bad Battery
8200 Bad Battery
Author
Message
der
View Quick Profile
Supreme Being
Supreme Being (101 reputation)Supreme Being (101 reputation)Supreme Being (101 reputation)Supreme Being (101 reputation)Supreme Being (101 reputation)Supreme Being (101 reputation)Supreme Being (101 reputation)Supreme Being (101 reputation)Supreme Being (101 reputation)
Last Active: 8 Years Ago
Posts: 3, Visits: 6
I purchased a new 8200 yesterday from lowes. After fully charging the battery (1hr) I began using it at half speed, the light flashed after 5min of use and went dead. I then charged again (1hr) and again after 5min of use dead.
Is this a defective battery?
TaosGuy
View Quick Profile
Forum Member
Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)
Posts: 2, Visits: 7
About Batteries!
The 8200 battery is 99% the same configuration as the Bosch 12V.
To use it just use your Dremel 8200 to trim the Bosch Battery. Use the EZ Lock with a "thin cut" wheel and trim the excess plastic away. Use the Dremel Battery as a guide.
My favorite "larger" tool brand is Bosch. So I have plenty of Bosch 12V batteries. They still work fine in the Bosch after trimming for use in the Dremel. The Bosch charger will also charge both.
Taos Guy
Taos, NM 87571
TaosMarketer@gmail.com
dacianfalcon
View Quick Profile
Forum Member
Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)
Last Active: 7 Years Ago
Posts: 1, Visits: 2
I noticed that the 8200 must be huge.
south florida marketing|south florida web design
Reading This Topic
