Dremel 4000
Dremel 4000
Author
Message
Dave9999
View Quick Profile
Forum Guru
Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)
Last Active: 8 Years Ago
Posts: 2, Visits: 4
Same problem as many others. Working fine, used for 5 mins with rotary sander on extension lead - just stopped. Warm but not hot and no funny noises or smell. I have noticed poor speed regulation round 5000 and don't believe the constant speed feature works well - occasionally the speed fluctuates at idle (ie before I start to use a tool). Am sending back to supplier (checked fuse in plug - OK). I have some electronics experience and suspect inferior components in the control circuit are to blame. Could be a bad batch or a design fault. I really like this tool and hope Dremel can sort out this problem for all our benefit.
dsdsds
View Quick Profile
Supreme Being
Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)
Last Active: 7 Years Ago
Posts: 11, Visits: 1
Each of our inexpensive cheap nike air max Shox as well as vintage variations will give you a totally distinct sensation. Next to the remarkable Nike Atmosphere nike air max 1 sale string as well as Nike Shox series.
Reading This Topic
