Sanding a nylon washer - Disks fill with Nylon !!
Author
Message
Happy Snappy
View Quick Profile
Junior Member
Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)
Last Active: 8 Years Ago
Posts: 1, Visits: 4
I have a small project where I have to reduce the size and increase the center diameter of a nylon washer, I have tried a 432 - 120 grit and it fills with nylon very quickly. I have also tried slower and faster speeds.
The nylon washer is only 2.5 mm width, 30 mm diameter and internal hole 10 mm - Please any idea's - Please !!
HappySnappy
Morpheuz79
View Quick Profile
Supreme Being
Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)
Last Active: 7 Years Ago
Posts: 4, Visits: 17
You should try with high speed cutters like #115 or #196 at medium speed.
I've worked on polycarbonate with good results.
D300 & a lot of stuff
dsdsds
View Quick Profile
Supreme Being
Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)Supreme Being (283 reputation)
Posts: 11, Visits: 1
Footwear is the most basic attire nike air max that the cager need. In this regard, you ought to not only put on shoes or boots that can withstand repeated do-it-yourself torture inside hardcourt and also the have to continuously nike air max 90 carry a cager weight.
Reading This Topic
