Dremel Message Board
dremel scroll saw 1672 Expand / Collapse
Author
Message
Posted 11/22/2011 12:14:47 PM
Forum Newbie
Last Login: 11/24/2011 4:38:04 PM
Posts: 2, Visits: 8
I have to hit the arm with a rubber mallet to get it to go fast, it will run on slow. I just want to fix it because I like it. I've had it for 11 yrs. I don't have a owner manual any more and was all so wondering if it takes plain end blades? Any help out there would be thankful
Post #8103
Posted 11/23/2011 11:46:32 AM
Supreme Being
Last Login: 12/2/2013 2:46:56 PM
Posts: 233, Visits: 598
Your scroll saw, like mine, has been discontinued. If Dremel customer service doesn't have a manual avail you might try google. With your "hit & run" approach it sounds to me like a loose wire or bad switch. You might end up having to by-pass the switch and direct wire it. Sears used to have a blade conversion kit available. Good luck!
Post #8104
Posted 11/23/2011 3:34:24 PM
Forum Newbie
Posts: 2, Visits: 8
Thanks for the info. I'll check the switch thing out. I bought a saw from sears and I'm taking it back. It is to crazy for the pin less blades to put in its a good saw but not for the pin less blades.
Post #8105
« Prev Topic | Next Topic »
Forum Moderators: AlyssaCicero
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 6:25am
Execution: 0.047. 7 queries. Compression Disabled.
