Thin cut
Thin cut
Author
Message
Bradley
View Quick Profile
Forum Member
Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)
Last Active: 7 Years Ago
Posts: 1, Visits: 3
I am looking for the thinest cut possible in plastic.
I have the hand held Dremel and am looking to cut a very thin line in plastic. As thin as possible, THIN! Thinner than the wheel that comes in the kit.
Is there an accessorie?
Thanks
Tony@Dremel
View Quick Profile
Forum Member
Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)
Group: Administrators
Posts: 2, Visits: 16
Hi Bradley – you can try a 409 cut-off wheel (.025" or 0.6 mm thick). This might be the thinness you're looking for, although we'd recommend testing the cut on a piece of extra stock first. Plastic can melt when you try to cut it, so you may need to try a slower speed or make multiple cuts in order for it to work. Good luck.
SharlinMinto
View Quick Profile
Forum Member
Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)
Posts: 1, Visits: 1
Hope this will also help me for cutting Pexigless acrylic sheets also!!Smile
corporate responsibility
Reading This Topic
