Cutting off a metal nail
Author
Message
Ramon Aclef
View Quick Profile
Forum Member
Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)
Last Active: 7 Years Ago
Posts: 1, Visits: 7
I have some nails sticking out of wood trim in my bedroom (my house's previous owner left a lot of half-finished projects behind). I don't want to pull the nails and risk detaching the trim, but the nails cannot be driven the rest of the way in. I'd like to cut them off flush with the trim. Can the Dremel 4000 handle this job? If so, which cutoff wheel would be best to use? The nails are 6d size.
I was planing to get a Dremel, but if a different version of the tool would be better, I'd like to know before I s**** out money on it.
Dremel Customer Service
View Quick Profile
Supreme Being
Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)
Last Active: 4 Years Ago
Posts: 109, Visits: 540
Hi, this is Beth from Dremel Customer Service.  The tool that you have will be perfect for the job you want to do.  We make our "Cut-Off" Wheels for just this reason... they are used for slicing and cutting metal, slotting bolts, screws, sheet metal, etc.  (also for wood and plastic as well).  You undoubtedly received some of these "brown/flat wheels with a hole in the center of them, in your kit.  For more usage on how to install them in your tool, please feel free to give our Dremel Customer Service Department a call on the toll free number of  1-800-437-3635. We are available Mon-Fri, 7:00 am - 6:00 pm, CST.
-Dremel Customer Service Team
lisaflrns
View Quick Profile
Forum Member
Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)
Posts: 1, Visits: 3
Climb Cut is most important when cutting sheet metal, but metal cutting disks work best cutting the opposite way to cutting wood.
miracle mineral
wemlento
View Quick Profile
Forum Member
Posts: 1, Visits: 1
Will you upload some image.
google apps marketplace
Zoneout
View Quick Profile
Forum Member
Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)
Posts: 1, Visits: 5
Hi !
My first post, and what a great Forum.
For this Job, yes i would cut with the disk, leaving about 3mm from your wall so not to mark the wall, then i would use the cylindrical Grinding bit to gringd flush to the wall.
Suppose allso it depends on the stediness of each Individuals hand,w00t so this would be my approach.
Z.OSmile
Go with the flow and your Art will Show
danyront
View Quick Profile
Supreme Being
Supreme Being (221 reputation)Supreme Being (221 reputation)Supreme Being (221 reputation)Supreme Being (221 reputation)Supreme Being (221 reputation)Supreme Being (221 reputation)Supreme Being (221 reputation)Supreme Being (221 reputation)Supreme Being (221 reputation)
Posts: 9, Visits: 3
I welcome you .I am also new here.
does women likes you
Reading This Topic
