What accessory to cut 3/4 inch plywood
Author
Message
dremelrook
View Quick Profile
Forum Member
Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)
Last Active: 7 Years Ago
Posts: 1, Visits: 3
new to the dremel and having a bear of a time trying to mkae cuts with the 561 bit my dremel 3000 came with. need to cut out dog shapes and be rather precise? is the wrong tool or there an accessory that can make help. Wood started to burn and felt like i was getting nowhere without more hand pressure. The tool is supposed to do the work but I must have the wrong bit??
Dremel Customer Service
View Quick Profile
Supreme Being
Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)
Last Active: 4 Years Ago
Posts: 109, Visits: 540
Hi, this is Beth from Dremel Customer Service.  The 561 Multipurpose cutting bit that you are using should do the job for you just fine.  You haven't stated what type of wood the "dog" is, but this bit will enable you to cut hardwood up to 3/8" and softwood up to 5/8".  Do remember, with this bit, it can't be used as a "drill bit".. meaning... do not enter into the piece of wood directly on... you should "plunge a 45 degree angle into the wood and then straighten the tool to a 90 degree angle.  Once in the wood, make sure that you have at least 1/8" of the tip protruding on the otherside of the material you are cutting.  If you don't, this can cause burning (also knots in wood or pushing your tool to hard can cause this as well).  If you have any further questions or concerns, please contact our Dremel Customer Service Department at 1-800-437-3635, Monday-Friday, 7:00 am - 6:00 pm, CST.  Any of us would be more than happy to assist you.
-Dremel Customer Service Team
Reading This Topic
