I need help with a design
Author
Message
saundra51
View Quick Profile
Forum Member
Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)
Last Active: 7 Years Ago
Posts: 1, Visits: 3
I have a design I am trying on 3/8" plexiglass for a splash guard between my sink and navigation station on my sailboat. I have a dremel tool that was my father-in-laws with many attachments. I have drawn my design on the paper backing and then used a bit to cut the outline. Does plexiglass need a lower speed....I am reviving it all the way up.
OR...can you suggest a video I can watch to help with this project.
Thanks...I am on a big learning curve!
Saundra51
Dremel Customer Service
View Quick Profile
Supreme Being
Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)Supreme Being (2.4K reputation)
Last Active: 4 Years Ago
Posts: 109, Visits: 540
****o, this is Beth from Dremel Customer Service.  In regards to the application that you are doing, the best bit that we have for cutting "plexiglass or plastic" would be our MultiPurpose Cutting Bit, #561.  This will allow you to cut wood, plastic, fiberglass, drywall, laminate, aluminum and vinyl siding.  When using this bit, if cutting into a piece of material, then you will need to start at a 45 degree angle, otherwise, off the edge.  Keep your RPM's running around 10,000 - 15,000 RPM.  (in otherwords, slow).  Cutting something like this can cause the plexiglass to wobble, so make sure it's secured tightly.  Good luck with your project!  If you have any further questions, always feel free as well to contact Dremel Customer Service on the toll free phone number of 1-800-437-3635, Monday-Friday, 7:00 am - 6:00 pm, CST.  Any of us would be more than happy to assist you!
-Dremel Customer Service Team
wayner
View Quick Profile
Supreme Being
Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)
Last Active: 5 Years Ago
Posts: 82, Visits: 547
When you cut plexiglass with the Dremel it has a tendency to melt.  The trick is to get the speed slow enough so that it does not melt but fast enough so that it cuts efficiently.  I have had to go over ther same cut again in order to remove the melt but if you are patient it does a nice job.
Wayner   Wink
Reading This Topic
