4200 and flexshaft
4200 and flexshaft
Author
Message
jimmybobby
View Quick Profile
Supreme Being
Supreme Being (111 reputation)Supreme Being (111 reputation)Supreme Being (111 reputation)Supreme Being (111 reputation)Supreme Being (111 reputation)Supreme Being (111 reputation)Supreme Being (111 reputation)Supreme Being (111 reputation)Supreme Being (111 reputation)
Last Active: 6 Years Ago
Posts: 3, Visits: 5
Just bought a 4200 dremel and the flexshaft to go with it since the Lowes guy said it would work on it. I am having no luck whatsoever in getting it on. Does the flexshaft work with the 4200?
Jimmy B
wayner
View Quick Profile
Supreme Being
Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)
Last Active: 5 Years Ago
Posts: 82, Visits: 547
To answer your question, yes it does.  You have to remove the nose piece then insert the adapter that comes in the kit into the chuck ( it is the long cylindar piece that has a square drive in the end) and then attach the longer nose piece that will allow you to attach the flexshaft.  In the end it will look like you put an extension on your 4200.  Hope this helps.  The adapters should have been in your 4200 kit in the blue accessory kit.
Wayner   Wink
Beth at Dremel
View Quick Profile
Supreme Being
Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)
Group: Administrators
Last Active: 4 Years Ago
Posts: 229, Visits: 4.3K
****o Jimmy, this is Beth from Dremel Customer Service.  It's true what the other user, Wayne, has instructed you in regards to putting the 225-01 Flex Shaft onto your new Dremel 4200 tool.  However, for users that have another Dremel tool, they can use their collet/collet nut from off of their other tool to put it into the end of the Flex Shaft. Otherwise, the 4200 does not provide the collet/collet nut for the Flex Shaft, so if you need these two items, please call our Dremel Customer Service Department to discuss this with them.  Any of us would be happy to assist you.  We can be reached on our toll free phone number of 1-800-437-3635, Monday-Friday, 7:00 am - 6:00 pm, CST.  Thanks for your inquiry!
-Beth at Dremel
jimmybobby
View Quick Profile
Supreme Being
Posts: 3, Visits: 5
Beth,
Can you tell me does the Dremel router atattachment work with the 4200.
Thnaks
Jimmy B
Beth at Dremel
View Quick Profile
Supreme Being
Hi Jimmy:  It's Beth from Dremel Customer Service.  I'm happy to inform you that our #335 Plunge Router does work with your new 4200 tool.  (Just remember though, if you need to change a router bit out during your project, you'll have to remove the tool to change the accessory okay?)  Glad I could be of assistance to you.
-Beth at Dremel
Dan ravert
View Quick Profile
Forum Newbie
Forum Newbie (7 reputation)Forum Newbie (7 reputation)Forum Newbie (7 reputation)Forum Newbie (7 reputation)Forum Newbie (7 reputation)Forum Newbie (7 reputation)Forum Newbie (7 reputation)Forum Newbie (7 reputation)Forum Newbie (7 reputation)
Group: Awaiting Activation
Posts: 1, Visits: 1
Any opinions on what to do with dremel 4200 I've had for 18 days and it won't turn on I didn't buy the warranty at Lowes and I don't have Tue cardboard box it came in I checked the brushes they seem Fine I really need this thing to work my business counts on it
Reading This Topic
